Trying to sort this out, but it's confusing, and I'm especially confused by this line in the documentation:
"Setting Bit-6 high of the register can be set high to multiplex Step/Dir generators 0-3 from JP7 to JP4 and JP6." - Huh?? generators 0-3 can be switched to JP4??? Which signals end up on which pins? This is not indicated at all in the connector pinouts.
Here's what I think I'd like to do:
Move my X/Y/Z/A Step/Dir outputs off JP7. Assuming the documentation that indicates generators 0-3 can be moved to JP4 is wrong, I'd like to move them to JP6 using Step/Dir generators 4-7.
Put the new drawbar stepper on Step/Dir generator 0, 1, 2, or 3, on JP7, leaving the 3 unused channels as available I/Os.
Can I do that?
Ray L.
> Tom,
> I currently have four axes - X, Y, Z(quill), and A(knee). These are all connected using IO8-15. I now need to add an additional axis, for the stepper motor that runs my power drawbar. What options do I have for where to connect STEP/DIR for the new motor? Is it only JP5?
> Regards,
> Ray L.
